Check engine light and very low idle
Old Jan 12, 2004 | 04:49 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
The vehicle is a 1991 Z28 w TPI 5.7
Here is kind of a "log" of what went on yesterday:
- 11:30am
Started Camaro. I usually wait a minute or so to warm up (get situated). It idled at 1000rpm for 30 seconds. Suddenly the check engine light comes on and RPMS took a nose dive to 200rpm but to quickly move to 500rpm. Check engine light stays on for 10 seconds with the motor surging between 500-600rpm. So I turned the car off and my drove truck to work.
(BTW I didnt put it in gear when all this happened).
- 12:30pm
Left work early to work on Camaro.
Got home, started vehicle, idle at 1000rpm for 20 seconds (normal), then a sudden surge to constant 500rpm with check engine light for 10 seconds,
then back to normal. Turned off vehicle. Checked for stored codes, none found. (??)
- 1:00pm
Started car. Ran for 3 minutes and never saw a problem.
- 1:30pm
Started car, immediately displays SES light and surges from 500-600rpm. Problem does not go away (I let it run for a minute or so as well as just "drive" around the parking lot).
I checked for codes (paperclip trick). Engine light just stays on. After a minute, I hear a click under the hood, fans come on, and it displays code 12 over and over. After it displaying code 12 about 5 or 6 times, the engine light comes on randomly and I hear that click under the hood again.
I probably COULD drive the car down the road to an Oreillys and have them do a code check but Im worried with the motor running this way.
Old Jan 12, 2004 | 11:12 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
might as well just delete this post
Old Jan 12, 2004 | 12:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Don't delete it Just repost on the TPI Board.
Since no codes are set, your best bet would be to have a scantool plugged in and monitor to see what's going on.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
