In car rebuild
Old Jan 12, 2004 | 06:58 AM
Snake Oiler's Avatar
Car: 84 Z/97 Tacoma 4X4
Engine: 350 H.O Crate,slp 1 3/4,3"catback,Edelelbrock 1406,Edelbrock perfrormer Endurashine
In car rebuild
I was wondering how hard it is to do this.
I know getting the oil pan off will be a PITA,but time is not an issue,I have all winter. I want to have the crank ground and change all the bearings.
Old Jan 12, 2004 | 07:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It would be about 4 times harder to do that than to pull the motor and do it right. I can't imagine how it could possibly be a good idea to do it that way.
Old Jan 12, 2004 | 08:06 AM
ede's Avatar
ede
in car rebuild would be the way to go if you want to spend more time and effort and get an inferior end result.
Old Jan 14, 2004 | 01:33 AM
INFERIOR????????? Hows that???????What can you outside the car that you cant do in the car??
Not trying to start an argument here.
More difficult,I agree.Time consuming also.I'got all winter to do it.
Old Jan 14, 2004 | 01:48 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
The only reason I can think of to do it in the car is that you have no means to pull the engine out and no where to put it once out.
I see you are in Highland, In. Shoot me a pm if this is the case. I may be able to help you.
Old Jan 14, 2004 | 02:01 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Things you can't do on an in frame rebuild:
Hot tank, bore, cam bearings, deck.... more.
I've done it, not on an F body tho. Go for it! you'll change your mind within 2hrs.
It's hard enough on an engine stand.
If you have to, you can use a come along hung from a tree or maybe your garage door frame (if you're careful)
Old Jan 14, 2004 | 05:55 AM
ede's Avatar
ede
yeah any sort of real cleaning or machining will be out of the question. every piston and rod will mean a trip under the car plus you'll be wroking aginst gravity with a couple of heavy pieces and a lot of small pieces.
Old Jan 14, 2004 | 05:57 AM
Hey there 88tbi4x4, you following me or what
I'm just posing a question, if it wasn't to bad I was just going to hone the cylinders have the crank ground ,put new bearings in.....I put new heads on last year and the bores looked real good, still had cross hatches, so I thought I'd just order those pistons you showed me and freshen it up.
But if it's that much of a pita i'll go the other route.
Old Jan 14, 2004 | 06:01 AM
Hey ede,Up early or late
Old Jan 14, 2004 | 08:26 AM
ede's Avatar
ede
early, i get up a 2:45 for work
Old Jan 14, 2004 | 12:18 PM
Car: '85 IROC
Engine: LB9
It's partly the graveyard shift deal I'm sure, and you keep asking questions that I know the answer(s) to.
So anyhow... if you start doing it in the frame, and you change your mind you can always take it out and do it the other way. What the hey... Maybe you'll go for it and start getting into it.
Old Jan 15, 2004 | 12:31 AM
Yup,Know what you mean about the graveyard shift,me too. I hate it! What ya gonna do
And your right about the cam bearings to,cant change #5. So out it goes.
Glad you guy's are here to point these things out. Thanks!
ede, 2:45, DOH! So you gotta go to bed around 7 or 8,I could'nt do it man.
Old Jan 15, 2004 | 12:38 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Think about how silly this is. In order to take the crank out you need to undo the transmission so you can take off the flexplate. Then in order to take off the oil pan you need to unbolt the motor from its mounts and lift it up.... SOOOOO, once the transmission is out, and the motor is lifted why the heck would you leave it in the car? "Its like wiping your *** before you poop ...it just dont make any sense"
Old Jan 15, 2004 | 12:54 AM
Nice analogy, another point I didn't concider. Now i'm totally convinced.
I concied
I give
UNCLE!!!!!!!!
I have SEEEEEN the light.
Thanks!
Old Jan 15, 2004 | 12:59 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
"Its like wiping your *** before you poop ...it just dont make any sense" [/B][/QUOTE]
That was freakin funny!!! LMFAO!:yourock:
Old Jan 15, 2004 | 04:41 AM
ede's Avatar
ede
damn that is funny hope i can remember it to use agan later
Old Jan 15, 2004 | 08:11 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
lol!
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
djmarch
Aug 10, 2015 08:42 AM
hokis
Aug 9, 2015 03:57 PM
