car will not start
Old Jan 13, 2004 | 07:37 AM
three33three's Avatar
car will not start
car will not start
92 camaro 5.7 5speed
the timing belt moves slow, and i hear i rattle sound when i try to start it(rattle sound comes from the motor). battery is good and starter is good and timing blet is in good shape (ANY TIPS?)
Old Jan 13, 2004 | 07:44 AM
acid Burn's Avatar
Car: 89 IROC
Engine: 5.7 TPI
Transmission: 700R4 w/ transgo kit
rattling sound? that could be your starter clicking which means its not getting enough juice to start your motor, get a voltage meter and test the power going into the starter/seloniode
Old Jan 13, 2004 | 08:09 AM
ede's Avatar
ede
i think you need to take another look there isn't a timing belt to be good or bad let alone move.
Old Jan 13, 2004 | 11:42 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
maybe he means the serpentine belt.
BTW 33, did you put that 350(5.7) in place of a 305(5.0) or did you put the 5 speed in place of a 700R4?
Old Jan 13, 2004 | 06:04 PM
when i took it to the shop last, one of the auto techs said it sounds like a broken crankshaft (they did not do any test on it, it was only a guess),but if there was a broken crank why does the belt still move on the front of the motor ?
Old Jan 13, 2004 | 09:57 PM
Vader's Avatar
3333,
Find another "technician" - One that will actually remove the inspection cover from the bellhousing and find the problem, rather than guess. Snapped cranks in anything but Dodge V-10s are pretty rare.
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
L98GTA87
Aug 5, 2015 11:02 PM
