Stock vs aftermarket TPI with supercharger
Old Jan 19, 2001 | 10:15 AM
R.O.B.'s Avatar
If I plan on installing a supercharger, does it really matter that much if I use the stock TPI intake or go with an aftermarket one like the Superram? I ask because if its under pressure, will the stock one still be that restrictive? Would this be a major difference in power, or just slight (because of boost)?
Rob
'86 TA 305 TPI
Old Jan 19, 2001 | 03:39 PM
R.O.B.'s Avatar
Anyone? Any Thoughts, ideas or opinions?
Rob
'86 TA 305 TPI
Old Jan 19, 2001 | 03:46 PM
theformula's Avatar
Depends on the blower. Paxton6psi sn2000 -ATI P1SC 9psi are meant for stock motors. (anything over 9 isnt to safe on a stock bottom anyway) .
Modified engines (heads, intake) will produce less boost with these same blowers. Unmodified engnies produce advertised boost usually.
If you plan to go all out, you should look into the D1SC.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Cold air ind. w/K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, SLP headers & catback,short shifter,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Jan 19, 2001 | 04:19 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
From what I understand, a stock or a ported TPI system will work better than an aftermarket TPI like the super ram. I don't exactly remember why but I do remember reading something about the time it takes to get pressure in the system. The blower has to move more air to fill up the SuperRam than it does for a standard TPI. I think it was in one of the last 2 issues of GM High Performance. Hope that helps!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, (8.5mm Jacob wires, MSD Blaster coil, S&R subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Steve78LT
Feb 24, 2016 12:15 AM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
