BIG Starting Problem
Old Jan 15, 2004 | 07:04 PM
Bvonscott91RS's Avatar
Car: 91 Camaro RS
Engine: L03 V-8 TBI
Ok Last 8 months or so whenever I start my car it takes 8-10 turns of the key to ignition to start my car. The starter would click each time. Just had my transmission rebuilt by a shop. After driving it about 6 times it would not start. Checked battery, bought and installed new neg and pos cables. Took starter to autozone and it tested perfect. When key is in on position everything works fine. When i turn the key to start nothing happens except the fuel temp guage flicks over and my !Brake light lights up. And I tried it in park and nuetral. So I need some help! THanks.
Old Jan 15, 2004 | 07:09 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
does the security light come on? if it does its probably a vats problem.. if not i'd look to the neutral saftey switch located on the side of the shifter..
Old Jan 15, 2004 | 07:15 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try starting it in reverse, drive or one of the other gears. If it starts, then the park/neutral switch is not properly adjusted. You also mentioned that you had just had the transmission rebuilt, you might want to check the transmission cable where it connects to the transmission. It does not sound like a VATS problem at the moment.
The Trickster!!!!!!!!!!!!!
Old Jan 16, 2004 | 06:51 AM
Pat Hall's Avatar
Another thing about the vats. If it's working properly, the security light will come on for a couple of seconds, then go off when you first turn the key over. If the security light stays on or doesn't come on at all, then you have a vats problem.
Old Jan 16, 2004 | 08:22 AM
89RsPower!'s Avatar
you can adjust a neutral saftey switch? how?
Old Jan 16, 2004 | 10:18 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, the park/neutral switch on an automatic can be adjusted. I can e-mail you the information if you need it.
Old Jan 16, 2004 | 03:10 PM
89RsPower!'s Avatar
i don't actually need it for any particular reason but i would like to know just for my knowledge, like to learn new things, never know when your gonna need it.. plz post it here if ya can, if not i'll pm ya my email address.. thanx man
Old Jan 16, 2004 | 05:38 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
An inquiring mind.....HUH!! Okay Matt, You have e-mail:lala: :lala:
The Trickster!!!!!!!!!!!!!!!!
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
