Water for coolant
Old Jan 17, 2004 | 03:32 AM
Wezzeles's Avatar
Car: Camaro
Water for coolant
im thinking about running water and some redline water wetter in the spring. no coolant. comments? things i should know?
Old Jan 17, 2004 | 04:57 AM
Vader's Avatar
From what I can determine, Red Line wateer wetter has no properties other than improving the heat transfer of coolant.
You should still have something in your coolant as a corrosion protection, and to help lubricate the water pump seal. As I recall, for standard PEG antifreeze solutions, the minimum recommended concentration is something around 12-18% to ensure that protection.
Old Jan 17, 2004 | 10:42 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Water for coolant
Yeah water works great. Distilled (not spring water) will work better with less corrosion.
Old Jan 17, 2004 | 10:44 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Re: Re: Water for coolant
Like he said.
Don't use any old tap water.
Old Jan 18, 2004 | 01:10 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
RLWW actually does have some corrosion inhibitors and they work quite well, however think of the amount of RLWW as compared to your coolant system volume. If it were me... well 60/40 (DW/AF) is what I run.
Old Jan 18, 2004 | 01:32 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Water just seams to work the best as long as you can remember to coolant up the mix when it gets colder.
A few times in my life I had a hot car that would puke coolant but be happy as heck with tap water when it was a screaming hot summer. I also delievered pizza then. stop,go,stop,go.......
Old Jan 18, 2004 | 01:35 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ohh and why not just dump a quart of water solvable oil in it???
I often wondered about that when even after a good flush the system looked rusty. Run some oil through it and lube the block.
Old Jan 18, 2004 | 10:23 AM
Vader's Avatar
I guess I've never analyzed the Red Line content label that closely, and in poking around my inventory, it appears that I need to resupply before the spring maintenance cycle. I also have a quart bottle of Prestone corrosion inhibitor/water pump lube (which is probably just a soluble oil or wax) that might satisfy your needs.
BTW - Good to see you're still lurking about. You were stuck on '666' for quite a while.
Old Jan 18, 2004 | 12:53 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Well, been busy at a new firm, and I kinda liked the '666' maybe Dirk will p/u and lock it back there eh?
Old Jan 24, 2004 | 08:09 PM
Larry's Avatar
Car: 86 Corvette
I read that Redline water wetter was developed by an engineer that was trying to make a corrosion inhibitor for race cars because some circle tracks don't allow antifreeze. The heat transfer improvement was unexpected. I use 20% antifreeze and water wetter in my TPI S-10 and the temperature on a hot day now runs 180 instead of 200+. I add more antifreeze in the fall and flush the radiator every spring.
Old May 9, 2014 | 09:38 AM
Gary Dan's Avatar
I have a 1988 Camaro convertible,,(305 v8),,, put on a daytona hood for better air flow & use wetter water and this seems to solve my overheating at this time. However summer is not in full bloom yet.
Old May 9, 2014 | 09:51 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Hello 10-year old thread, lol.
Gary Dan, if you look at the top left corner of the last post on a thread it will tell you when it was posted, chances are the original poster on this one hasn't been on in years.
just a friendly heads up
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
