check engine light
Old Jan 17, 2004 | 06:01 PM
JamFitz's Avatar
Car: '89 FB TA GTA
Engine: ZZ4 tpi
Transmission: 3.27 auto: stock gear box
Axle/Gears: Stock
check engine light
Hi all, Just got the baby fired back up after 4 weeks out in the very very wet and frosty scottish wildness, Unfortunatly it cant be garaged at the moment. The check engine light is comming on and it wont idle. Any one got any ideas where I should start? Idle control valve likely?
Cheers for the help
JAmes
Old Jan 17, 2004 | 06:15 PM
ULTM8Z's Avatar
Need to find out what the SES light is coming on for. Jump the A-B terminals on the ALDL, turn the key on (not the engine) and see what the SES light blinks out. Should blink out a code 12 three times before it starts blinking the trouble code.
Old Jan 17, 2004 | 08:22 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Some info about the car would also be helpful. Year engine that kinda stuff.
Old Jan 18, 2004 | 09:40 AM
JamFitz's Avatar
Car: '89 FB TA GTA
Engine: ZZ4 tpi
Axle/Gears: Stock
ehh.. yeah sorry. 89 firebird GTA- 5.7 tpi. (i think thats it)
Will try the short the connectors today.
thanks
JAmes
Old Jan 18, 2004 | 10:40 AM
dankhound's Avatar
Car: 91 RS
Idle Air control could be your problem. You might want to pull it off and see if its stuck closed. If its all carboned up you might be able to clean it and get it to work.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
