What valve springs will handle .560" lift?
Old Jan 18, 2004 | 07:24 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
As Above.
TIA
Old Jan 18, 2004 | 08:50 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Well, if you are running a cam with .560 lift then use the recommended springs for them. Every cam has a recommended spring that you NEED to use otherwise you risk them binding, breaking and/or floating.
Old Jan 18, 2004 | 09:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Doc,
Your spriing pocket size makes a difference,t ake a gander through Comp, etc, and match a similar cam for you setup (assume hyd roller) and see the recommended springs...pay attention if they are 1.25 diameter vs larger diameter.
Then head to Jegs/Summit, etc, and price'em out.
Old Jan 18, 2004 | 09:27 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
comp cams 987 spring set is the one you are looking for....
Old Jan 19, 2004 | 04:40 AM
ede's Avatar
ede
really depends on your cam, match the springs to the cam. 2 cams with same lift may take differant springs, rollers use lot more spring than a flat cam.
Old Jan 20, 2004 | 08:23 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I'm looking at a Comp Cams 224/230 .560 valve lift and its a hydraulic roller cam. BTW: I am running AFR 190cc heads.
The 987 dual springs are recommended by Comp Cams. pg 338.
deracer
Apr 11, 2016 12:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
