Main cap bolt torque??
Old Jan 19, 2004 | 02:47 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I can't find in my haynes manual wut the torque is sopposed to be on the main cap bolts. I remember the last engine i built I used arp bolts and they said liek 65 i belive. So what is it with stock bolts?? also what are the rod bolts sopposed to be at? thanks guys
Old Jan 19, 2004 | 03:19 PM
ede's Avatar
ede
i'd find my manual before i'd trust someone on here to give me the specs.
WAG mains 70 ft/lb, rods 40 ft/lbs
Old Jan 19, 2004 | 03:41 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
60 on the mains and 40 on the rods.
Old Jan 19, 2004 | 07:37 PM
Vader's Avatar
Stock, 2-bolt caps?
Old Jan 19, 2004 | 08:13 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
We need way more info from you.
What ARP bolts are you using?
What type of lube are you using?
and what Vader asked?
Old Jan 19, 2004 | 09:32 PM
Car: 89 Formula
Engine: Carbed 5.7
2 bolt-1 peice rear main seal. stock bolts. I had the short block built and i just wunna make sure.
Old Jan 19, 2004 | 09:41 PM
AJ_92RS's Avatar
http://www.torquespecs.com/
Old Jan 20, 2004 | 01:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Are they new bolts? I'd be nervous about reusing old bolts there...
84z96L31vortec
Aug 20, 2017 12:16 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
