Diverter valve?
Old Jan 14, 2001 | 11:42 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Diverter valve?
I broke what I believe is the diverter valve for my air pump. Well, smog check is comming up, and I don't remember how it hooks up. There are four tubes, and one vaccum hook up. I know that one pipe comes from the pump, and two others go to the exhaust. What does the other one go to? and where does the vaccum come from?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 15, 2001 | 12:10 AM
Bort62's Avatar
OKay
one Goes to each manifold Air injector Bank
One goes to the pump
and The other Goes to the Cat.
The Vaccum line comes from the carb ViA a temp actuated vaccum swich, PLugged into a ported vaccum source ( i belive )
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old Jan 15, 2001 | 12:43 AM
stingerssx's Avatar
Nothing goes to the cat. Too early. Thanks anyway.
Old Jan 22, 2001 | 04:48 PM
stingerssx's Avatar
anybody? Bort? Vader? Anyone?
Old Jan 22, 2001 | 04:58 PM
CamaroMike's Avatar
The other one is the exhaust/bypass line and goes to the air pump muffler or air cleaner. What do you mean one does not go to the cat? Two go to the manifolds, one to the cat, one is the inlet, and the other is the bypass exhaust.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 23, 2001 | 03:47 AM
stingerssx's Avatar
I have an '82, and it doesn't have a tube going to the cat.
Or is it supose to have one? I thought that they started that in '84? It didn't have one when I took it off. Come to think of it, the cat didn't have a tube on it.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
