balencer Size....please help
Old Jan 20, 2004 | 06:12 PM
arlockstedt's Avatar
Car: 89 Firebird Formula 350 WS6
i have an 89' Firebird Formula 350 WS6. Was looking to order a new balencer but don't know the size and if it is extranally or internally balenced. Let me know. Thanks
Old Jan 20, 2004 | 08:38 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if its the origional engine its internally balanced.
Old Jan 20, 2004 | 08:59 PM
what size is it though?
Old Jan 20, 2004 | 09:04 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
My stock '87 350 damper is 6-3/4" dia....
It should be internally balanced.
Old Jan 20, 2004 | 09:07 PM
89RsPower!'s Avatar
6 and 3/4ths or 8".. I've seen both on these cars stock.. not sure which one for which years though.. or if it makes a difference.. maybe someone else knows for sure.. AFAIK any neutrally balanced one should be fine.
Old Jan 20, 2004 | 09:17 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
You can use any size, the larger like 8" will work better (reduce the bad vibes) the down side is they usually weight more. A smaller, lighter one will let the engine rev faster. can't you just bust out a tape measure on your existing damper/harmonic balancer?
Old Jan 20, 2004 | 09:30 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thats what I did. My stock bottom end 350 is sitting on the floor. A new 395 will be going in. I measured that factory damper with a tape,,, 6 3/4" dia. And I know that these engines are internally balanced.
onfire
Dec 28, 2006 10:50 PM
black85iroc
Mar 16, 2005 04:24 PM
BOTTLEDZ28
Sep 13, 2004 06:43 AM
89formula#1
Aug 9, 2002 12:29 PM
89formula#1
Jul 25, 2002 12:04 PM
