harmonic balencer question
Old Mar 15, 2005 | 03:37 PM
black85iroc's Avatar
Car: 1985 camaro IROC-Z
Engine: Lg-4 305
Transmission: t-5 5 speed
so i got the motor in my car last summer from a junkyard and it never had a timing pointer on it (and im not sure what the hell it came out of), so i threw it together and guessed when i first built it. now that i have time over the winter to do things right i decided to pull my balencer off and measure it to order a new pointer. so i pull it off and i measure 6 and 3/4" of an inch, so i go over to my trusty summit racing catalog only to find they dont make a pointer for a 6 and 3/4" balencer, only 6, 6 1/4, 6 3/8, 6.6 and 7. is 6.6 close enough? or should i find a company that makes one?
or am i retarded and did i measure wrong? please help me out
-Adam
PS i just checked and summit makes and sells a 6 and 3/4 inch balencer so im probably going to call and ask them about it but until then anyone got any imput?
Old Mar 16, 2005 | 04:39 AM
Night rider327's Avatar
Car: 1988 Camaro
Most of them cheap pointers are wrong anyway. I had 1 with the right damper and it was 3* off.
What I done one engine, was JB welded a bent out paper clip to the timing chain cover in the right place
On my last engine (one in my 88 camaro now), I took a cheap chrome bolt on one, and marked it for ture TDC and cut the tab to a point.
You'll need to find ture TDC with a piston stop to do that. Then just make you a dot on the timing cover or cheap tab in line with the hash mark on the damper, then cut or put a pointer on that dot you made, now you know for sure where true TDC is
When I had a stock damper, I bought one of the $20 degreed proform damper covers, so I would have timing marks alittle around, not just 18* or so like the tabs has
Then I bought a PP 6.75" damper and it is degreed
Old Mar 16, 2005 | 10:01 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Is that the Professional Products Powerforce Damper?What do you think of it so far?
Old Mar 16, 2005 | 04:24 PM
Car: 1988 Camaro
onebad82z... Yep Professional Products.
I like it. It's a well made damper. Solid bonded outter hub, full timing marks, good balance to it.
IMO one of the best buys for the buck when it comes to better aftermarket dampers
gixxer92
Sep 1, 2015 04:32 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Eric2ndGen
Aug 31, 2015 12:33 AM
theshackle
Aug 22, 2015 06:52 PM
redmaroz
Aug 16, 2015 11:40 PM
