ever changed the water pump on a 86 LG4?
Old Jan 23, 2001 | 07:18 PM
zee28's Avatar
Car: 86 iroc
I got everything off but I cant get the power steering pump bracket loose to swing it out of the way.Which one of the 500 million bolts do I have to loosen.I took out the 3 I see holding it but it wont move.Do I have to take the air cond.brackets off?thanks
~mike~
1 superclean 86IROC-Z
Old Jan 23, 2001 | 08:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's 4 bolts: 2 on the back, the one that goes into the pump, and the nut on the top. The lower one on the back is the one you haven't found yet. It's a 9/16" like the one you did find.
You don't have to take the A/C brackets off.
ICON Motorsports
Old Jan 23, 2001 | 08:44 PM
R.O.B.'s Avatar
While playing with my timing chain, I left the power steering alone, just pulled the pump right out at an angle, and installed the same way.
Rob
'86 TA 305 TPI
Old Jan 23, 2001 | 09:34 PM
zee28's Avatar
Car: 86 iroc
I planned on just moving it aside,but it wont move at all.I will look for the bolt in the back.thanks alot.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
