Car Starts But Goes Dead Afterwards...
Old Jan 22, 2004 | 10:07 PM
Dark Man C's Avatar
Car: 1989 Trans Am GTA
Engine: 350 5.7 L98
I changed my valve cover gaskets on my '89 L-98 GTA
the other day.Everything I thought went smoothly they came off and went back on.
Now when I start the car it runs for about 30 seconds and goes dead.It ran fine till I changed the valve cover gaskets.Can someone tell me what have I done wrong and how can I fix the problem?
Any help you guys can give me will be appreciated and trust me i need help badly with this problem.Thanks in advance for any help and/or suggestions!
Old Jan 22, 2004 | 10:16 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
sounds like you have a vacume leak (a bad one) my friend. Make sure all your vacume lines are connected where they should be. I know b/c I have gone through this before and I know how frustrating it is. Do that and your problem should go away.
Old Jan 22, 2004 | 10:22 PM
Dark Man C's Avatar
Engine: 350 5.7 L98
I will check for vaccum leaks.But I was extra careful not to take
anything apart or loose that did not need to be disconnected.
Thanks for the pointer...
Old Jan 22, 2004 | 10:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Also check to make sure you didn't pinch a wire or vacuum line under the valve cover.
The Trickster!!!!!!!!!
Old Jan 23, 2004 | 10:43 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If you bend those old vacuum lines they break pretty easy.
Old Jan 24, 2004 | 09:32 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
my car is doing that also after a head gasket install, turns out the rubber boot that the pcv hose goes in had a huge 1/4 inch crack all the way down it.
Its those damn gremlin you know!
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
hokis
Aug 9, 2015 03:57 PM
