"Hot Cam" in a 406?
Old Jan 24, 2004 | 03:45 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
"Hot Cam" in a 406?
Can this roller cam work in a 75 400 sbc? I plan on using a retrofit hyd. roller lifters from comp cams. But the big thing is how the cam is held in the older block. I guess the newer roller blocks use a plate to keep the rolller cams from moving wheras the older blocks had 1deg ground into the lobe and used spring pressure to keep the cam from moving.
Cam buttons, thrust plate, block protector plate etc etc. Do any of these allow for using the LT4 hot cam in a older block. I am planning on a HSR 406 as more of a street engine and think the hot cam would work good in this application.
Any help is greatly appreciated
Old Jan 24, 2004 | 05:27 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
Did a little more searching
And found that if I machine off the ears off the newer retaining plate and use a cam button the hot cam should work. And make sure to use a 87+ timing chain.
Old Jan 24, 2004 | 06:05 PM
ede's Avatar
ede
you might want to think about how you're going to locate or hold the lifters too.
Old Jan 24, 2004 | 06:09 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Sounds like he's going to use Comp retro rollers, ede.
But where did you find out about machining the ears off the spacer?
I assumed that wouldn't work, cause the ID of the spacer is so much bigger than the dia of the part it rides on, it seems like it would shake all over the place. But what do I know?
Also where do you get a cam button that fits an 87> timing sprocket?
I'd like to find out. Thanks
Old Jan 24, 2004 | 07:45 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
I did a search and found this.
https://www.thirdgen.org/techbb2/sho...ghlight=button
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
