how do I get water pump pulley off?
Old Jan 24, 2001 | 11:35 AM
zee28's Avatar
Car: 86 iroc
Is there a strap tool or something to hold the pulley while you loosen the 4 bolts?or is there another way?thanks
Old Jan 24, 2001 | 02:20 PM
84FTA's Avatar
If you leave the belts on there is usually enough friction. Make sure you're turning the bolt the right way and hold the pully with your hand. You may be able to get vice grips clamped on but I don't think they'd hold too well.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 Trans Am T-tops
4-bolt main 350, headers, Holley 650, T-5, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Jan 24, 2001 | 09:37 PM
Vader's Avatar
Z28,
Yes, Ridgid and several other companies offer high-quality strap wrenches that are ideal for such purposes. I've always found it easier to leave the accessory belts on to loosen the nuts, then remove the belts (like 84FTA said).
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 25, 2001 | 02:17 AM
Pat Hall's Avatar
In addition to leaving the accessory belt on, use a wrench and hit it with quick blows from your hand or smack it with a hammer. Pulling slowly on the wrench usually makes the pulley slip. Nice sharp blows usually gets the job done.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 12, 2015 11:33 AM
