Effects of Higher Octane
Car: 95 Trans Am
I usually put 87 octane gas in my car but it was running really badly. Sometimes i would hit the gas and actually slow down before i sped up but even then i barely accelerated. I've recently started using 92 octane gas and my car has become an animal. It never hesitates anymore. Now, i floor it and it moves like a beast. Here's my question though. I used to get better gas mileage on the 87 octane. What's the difference? Is it just the amount of oxygen in the gas? Can using a higher or lower octane have any permanent positive/negative effects?
Car: 89 Camaro RS
Engine: 305 TBI
Well I don't know of any long term effects (if any) of running a higher octane fuel.. except race gas.. But basically what the higher octane does is slow down the combustion .. thus yeilding a little more power.. on my car I never really noticed a difference.. but I run midgrade on mine.. which it seems to prefer over the regualr and the premium..
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
Storms: "I used to get better gas mileage on the 87 octane."
That's probably because you weren't "trying to feel a power difference" when you used the 87 octane. Those numbers on the pumps to strange things to people's minds. Depending on your compression ratio you might not have any use for the higher octane ratings at all. Any change in gas mileage shouldn't get worse with the higher ocatane either, in my opinion/experience. If your engine needs higher octane than what you're running, you'll definetly know it- i.e. knocking.
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
man, you guys are in the darkages for octane.....
About the lowest I can get over here is 95!
I think what we can get is 95 as standard, 98 as super, and 100 as the premium!
Sounds like your engine is setup to expect 92 or more. You'd probably need to retune the engine for anything above or below what it was setup to run on.
Si.
I think what we can get is 95 as standard, 98 as super, and 100 as the premium!Sounds like your engine is setup to expect 92 or more. You'd probably need to retune the engine for anything above or below what it was setup to run on.
Si.
Yikes!
Even having worked in an oil refinery I never realised there was so much to it. Also scarily enough, me brother just sent me an email (completely unprompted by this thread) with this www page all about octane etc.
http://www.faqs.org/faqs/autos/gasoline-faq/part3/
A lot of reading but interesting enough.
Si.
Si.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Si.
Si.
The way we get the number on the pump is by averaging "R" and "M." Or, put another way, "(R+M)/2." So, if the RON of a fuel is 93 and the MON is 87, the octane rating you see on the pump is 90.
atleast, thats how it is in the states...
gas is also alot cheaper here... :lala:
Storms Of War :
most likely whats happening is your engine would see a knock with the lower octane gas, and pull timing.... hence the lil bog.
you should be able to run 87 in your car without a problem
(i'll space that out so everyone can see it)
the reason you're having a problem right now, is your engine is more likely to detonate then it should..... id suspect carbon deposits inside....
Transmission: 4L80E/4L80E
I thought you didn't have a car.
https://www.thirdgen.org/techbb2/sho...hreadid=220549
Car: 95 Trans Am
RedLeader289
May 28, 2019 01:47 PM
Damon
Sep 26, 2015 04:29 PM
