Hidden engine light problem......help!
Old Jan 25, 2001 | 03:23 PM
Blazin91Z28's Avatar
I recently bought a 91 Z28 w/ a 5.7l engine. The seller told me that occasionally while he was driving it the check engine light would come on and the engine would suddenly just idle and would stay that way until the car was turned off. He said that when it happened he would pull off the road and shut the engine off for a few minutes,then when he would restart the engine it would be fine. I have driven the car about 200 miles since i bought it and have not had any problem yet. How can I fix this from happening? The seller said he thinks it is a loose wire connection somewhere. If this is the case, where would it be?
Old Jan 25, 2001 | 03:53 PM
Blade's Avatar
Pull the codes from the ECM first then come back and tells us what you found. You really diagnose the problem with the info provided so far...
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
