car stalls whenever i turn
Old Jan 27, 2004 | 02:12 PM
thechristopherh's Avatar
whenever i make a turn at slow speeds my car stalls unless im giving it gas. Its only been doing this for about 2 days. i have enuff PS fluid. any suggestions?
Old Jan 27, 2004 | 02:25 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
Drive only in a straight line.
Has to be a fuel delivery problem. Maybe a loose wire or something. Does it happen when the fuel tank is full of gas or when it is nearing empty? It may be a fuel pickup problem.
Old Jan 27, 2004 | 02:50 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Are there any other symptoms? Does it die peacefully or stumble really bad before stalling?
Old Jan 27, 2004 | 03:08 PM
91FirebirdFmla's Avatar
Car: Green 1991 Firebird Formula
I know that some cars have a switch in the power steering system which either increases the engine idle when the system is under a heavy load or decreases the power assistance so that the load on the pump doesn't cause the engine to stall. I'm not sure of third-gen cars have that switch, but it is something to look into.
Old Jan 27, 2004 | 03:23 PM
dies peacefully
Old Jan 27, 2004 | 06:27 PM
changed fuel filter and PCV valve (i was told those could be the problem) and it still does it. my car does run somewhat better but none the less, it didnt fix the problem
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
