400HP L98
Old Jan 24, 2001 | 07:48 PM
StCr19's Avatar
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
400HP L98
Would it be easy or hard to get 400HP out of an L98? What would it take?
New cam obviously, SuperRam intake manifold maybe...
1986 Camaro
Carbureted 305
700R4
Old Jan 24, 2001 | 10:52 PM
Vader's Avatar
Saint,
Build it for RPM with a flat torque curve, and you can get over 400 HP easily. I've got a 355 that does 423 HP on the dyno at 5,800 RPM, and it only has .477 net valve lifts and hydraulic lifters, and IRON heads. This is a two-bolt block with added four-bolt caps on the center mains, stock stroke, 5.7" rods, slightly domed pistons (10.8:1) and 2.02" valves. It uses a (yuck) Holley and Edelbrock Performer. No special parts that you can't buy from any of dozens of places. I'm sure the RWHP is more in the range of 350-375, but I find it adequate.
A TPI engine might have a little harder time making power at those levels because of the fuel delivery/RPM limits of the induction system. A SuperRam would likely address that fairly well, but you'll have some ECM issues to contend with.
I'll bet there are quite a few naturally aspirated 400+ HP L98s around here somewhere...
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 25, 2001 | 05:31 PM
StCr19's Avatar
Well, I was going to use a SuperRam base intake manifold.
I'm not sure if I'll have enough money for the plenum and runners...
Should I just go with a carbureted engine? I havn't purchased anything yet.
Old Jan 25, 2001 | 05:36 PM
Biochem's Avatar
Car: 2002 SOM z28
Go carbed... welcome to the darkside!
Edelbrock heads, Compcams XE262H-10, 9.5:1 cr, Holley 750vac carb, Performer manifold, 4-bolt main, etc..
And it passes the sniffer!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jan 25, 2001 | 07:05 PM
Dan91Z's Avatar
but does it pass the gas station.......
My `91 Z28 Convertible
Old Jan 26, 2001 | 07:31 AM
Biochem's Avatar
Car: 2002 SOM z28
With the electronic Q-jet, I got close to 27 mpg on the way home from VA when it was cold outside (lower then 60F) and about 25 mpg comming from Charlotte when it was 90+F outside.
So yes, it does pass quite a few gas stations during the week + between fill ups...
Old Jan 26, 2001 | 11:30 AM
FastBroker's Avatar
Biochem, you got any dyno/guesstimate hp/torque numbers on your combo???
Vader, just to check: You have performer manifold, not RPM, right? what cam/lifter combo are you using, names please. Also, what heads and what have been done to them...
Just doin' a little research for next carb motor: Vortec heads (to be STOCK ports), springs, studs/guideplates, XE262 from COMP or HOT cam, either one to be run with 1.6 Roller rockers, possible Edelbrock 750cfm vac sec carb, RPM Air GAp manifold, GM HEI ignition. Looking for clean/easy/reliable 400hp on the dyno, that's all.
Any ideas?
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
abray1
Sep 10, 2015 04:53 PM
