Solid cams vs. knock sensors?
Old Jan 30, 2004 | 09:24 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
excuse my lack of knowledge
I am looking into a cam, and have never run a hydraulic cam in any motor I have built. They have all been carbed and I would like to try to learn the whole EFI thing and keep my TPI.
Would a mechanical cam or a mechanical roller make the knock sensor take false readings?
Old Jan 30, 2004 | 09:55 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
Dang it, meant to post this in TPI section
Old Jan 30, 2004 | 10:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably not.
Knock sensors are "tuned" to the specific resonant frequency of a bore size. As long as the mechanical noise produced by the valve train doesn't "sound" too much like a 4" bore to the knock sensor, it won't hear it.
Old Jan 30, 2004 | 11:03 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Tech is close enough.
Only thing I know is what I've heard. I've "heard" that solid lifters and gear cam drives will mess with the sensor's head. I don't have any "solid" evidence to that, however.
FWIW, my daughter's '92 Lumina was running like a dog. After replacing the noisy water pump & alternator (both of which were operating fine otherwise), it "seemed" to have more power again.
Old Jan 30, 2004 | 11:13 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
Is there a way to delete the knock sensor in any way?
Old Jan 30, 2004 | 11:25 AM
ede's Avatar
ede
you can add a resister in line but i don't know the value of it or wrap the knock senser with some extra teflon tape to make it less sensitive to false knock.
Old Jan 30, 2004 | 11:36 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
my friends gear drive did cause alot of false knock with his motor.
he eliminated the knock sensor by using a resistor... i dont know the resistance either... if someone knows it, please post up.
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
