belt question, water pump slippage?
Old Jan 30, 2004 | 11:43 AM
no_car_yet's Avatar
when i remove my AC + smog and all that other crap, i will have a shorter belt( 50 3/4 ") to go around the PS, alt, crank and waterpump. in order to keep everything spinning the same way, the belt has to come clockwise around the crank and right up to the alt, and over the top, clockwise. the belt only touches about 1/4, if that, of the waterpump pulley inbetween(the crank and alt), and the waterpump goes counterclockwise.
anyway the question is, that with so little of the waterpump pulley coming into contact with the belt, think i will run into over heating problems. would it matter alot if the water pump sliped every now and then when i hit the gas?
Old Jan 30, 2004 | 02:39 PM
no_car_yet's Avatar
bump
so what would happen if the waterpump sliped?
Old Jan 30, 2004 | 09:31 PM
no_car_yet's Avatar
hmm
have i stumped TGO? or is everyone two lazy to type if it matters or not?
Old Jan 31, 2004 | 01:34 PM
no_car_yet's Avatar
do it matter if the waterpump slips?!?!
Old Feb 8, 2004 | 06:39 PM
no_car_yet's Avatar
alright
thanks guys for all the help .
i found it after, thanks to speed88, its dayco poly cog PN# 5060500 . it should work if you have the 2.5" alt pulley...you can remove the AC + smog stuff for $20. not bad.
Old Feb 8, 2004 | 06:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Just noticed your message... you were only going to have a quarter inch of the belt touching the water pump pulley? That doesn't sound good to me... I'd want a little more insurance on that water pump if it were my car. You could always go for one of those $500 Meziere electric pumps too... I believe they're still the most durable for actual street use.
Old Feb 8, 2004 | 08:19 PM
no_car_yet's Avatar
no, i didn't mean for it to sound that way...a quarter of the perimeter of the waterpump pulley is touched by the belt...it should be good.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
