2 V8's in one car?
Old Jan 30, 2004 | 12:04 PM
phaledax's Avatar
2 V8's in one car?
sometime down the road I want to put another V8 in my camaro
I figure you could build bolth of them up to have 700 HP each and and make it a all wheal drive since you would have to completely change the drivetrain all the gears an stuff. Im leaving out alot of details in this plan but basicly it would comeout 1400 HP AWD monster around 5,000 ibs. Has anyone else thought or done this?
Old Jan 30, 2004 | 12:07 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I think about it all the time
Old Jan 30, 2004 | 12:17 PM
phaledax's Avatar
it will fit all in if you look at the size if your engin bay and your trunk put the gass tank near the roof. one big problem is connecting the drivelines to the same one and asumming the the engines will move at different speeds. if you figure this out you could also turn one off if not needed. I know that one of the german car companys are making a car with 2 seperate engins in it maby they have some of the parts you would need to adapt to. the idea isn't that far fetched. just costly
Old Jan 30, 2004 | 12:18 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i've seen FWD cadillacs done up where the trunk had a northstar engine in it as well.....very cool, and very heavy. not to mention.....cut your gas mileage in half
Old Jan 30, 2004 | 12:33 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
yeah, it was called the Twin star, 300hp,in front and another 300 in the trunk. It ran like mid elevens if I remeber right.:hail:
Old Jan 30, 2004 | 04:47 PM
neubauej's Avatar
Car: 89 Formula
Engine: LB9
Transmission: WC T-5
Also the Hairy Hurst Olds of the late 60's has 2 8-71 supercharged 425 (?) ci v8's. The front one was hooked to a toranado front wheel drive system. It would smoke all 4 tires the whole way down the dragstrip.
Old Jan 30, 2004 | 05:33 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
The Hurst 442s was the first thing that came to mind. I just dont know how comfortable it would be between two hod burning engines. Hopefully this post wont get pulled or locked because it has been the trend lately.
Old Jan 30, 2004 | 06:03 PM
Abubaca's Avatar
How did Chip Foose build that Hot wheels "twin mill"?
....anyone see that car on Rides?
Old Jan 31, 2004 | 12:52 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
O brother. I can't fathom what it would look like. Sounds beasty. Pics or a sketch would further enlighten us.
:rockon:
:rockon:
Old Jan 31, 2004 | 03:46 PM
Morley's Avatar
Renault (sp?) made a production 2 engine car back in the 80's call the Alpine. It had a 6 in front and a 4 in the rear and was all wheel drive and was butt ugly to boot.
Old Feb 1, 2004 | 10:23 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
What about checking out the tracter pulls, they run 4-6 motors at the same time, are they all diff trannys goign to one axle? Maybe check out what they are doing and maybe adapt to ur design.
Old Feb 2, 2004 | 04:12 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Why not just drop in a Chevy 700 V16???
I remember when it was made and shown in Hotrod years back.
The father and sun team use a special over to weld two 350 V8s into one hunk, the bock, head, cam and crank were welded in that fashion.
Old Feb 2, 2004 | 03:59 PM
Car: 87 Firebird
Engine: 5.3 76mm
Well y not just drop in a V-12 then =], There would not be enough room under the hood for a block too much larger than a BB, But who knows u maybe able to run a v->8 in there.
What about removeing the fenders, could therbe enough room with a little lift, to fit two 8s side by side?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
