AIR & EGR removal
Old Jan 31, 2004 | 02:21 AM
1fast91rs's Avatar
Car: 1991 RS
Engine: 305 LO3(TBI)
Transmission: TH-700R4
AIR & EGR removal
my friend has a 1986 iroc z28 with a quadrajet that we are going to be replacing with a edelbrock AVS carb this coming week but we figured before we do that we are going to remove all the AIR pollution equipment and cap all the vaccuum lines and remove the EGR and get a block off plate for the manifold are we gonna run into any problems?
Old Jan 31, 2004 | 05:59 AM
ede's Avatar
ede
never fooled with one but doesn't the ecm have sensers attached to or working along with the carb? if so there maybe a detail or two to work out.
Old Mar 10, 2004 | 12:07 AM
IrocZonNos's Avatar
Car: 1988 IROC CONVERTIBLE
Engine: 305 TPI PAXTON SUPERCHARGER & NOS
Could you post pics and supply details on how and what parts to remove when eliminating the AIR pump.
Thanks in advance.
Old Mar 10, 2004 | 12:15 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
get a shorter belt, and remove the pump. this is a good time to get headers. but otherwise, jsut remove the pump. I can't remember if it has anything to do with the charcoal can, i don't think so. it's a pretty easy mod to do though.
Old Mar 10, 2004 | 09:31 AM
MdFormula350's Avatar
yeah its pretty easy if ur replacing the manifolds with headers that dont have the air tubes. even easier if u dont have cat since u dont have to worry about those airtubes eother.
basically the big black box next to heater control vavle can come out and just tape the two eletrical connectors somewhere out of the way.
next pull the pump pulley, then remove the belt, then unbolt the two bolts holding in the pump. its pretty straight forward and anything that connects to the black box or air pump or manifolds can come out like the big air hoses,etc..
if i removed egr on my tpi engine i will get a code (ses on) and i would need to disable it in the computer chip.
egr is one thing i want to keep.
the air system and carcoal canister dont seem to be to much related at all.
Old Mar 10, 2004 | 10:05 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
remember when replacing a computer controlled carb with a non-computer controlled carb you need to replace the CC dist with a non-CC dist
Old Mar 10, 2004 | 02:17 PM
1fast91rs's Avatar
Car: 1991 RS
CC?
Old Mar 10, 2004 | 02:26 PM
joshwilson3's Avatar
Old Mar 10, 2004 | 03:22 PM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
CC= computer controlled?
Old Mar 11, 2004 | 02:42 PM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
CC distributor?
What happens if you leave the CC distributor on there? I am putting a non-CC carb on my LG4, but I would like to know if anything will happen if I try to start it. Also, is it possible to remove all computer control from the engine, and what all would this involve?
Adam
Old Mar 12, 2004 | 03:02 PM
1fast91rs's Avatar
Car: 1991 RS
Originally posted by joshwilson3
What size plugs do you need to plug the holes in the manifold that the air tubes went into?
i would also like to know this?
dyeager535
Aug 28, 2015 08:10 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
