Dropping a 350 in w/ the tranny already in the car
Old Jan 27, 2001 | 04:56 PM
Mike86Z28's Avatar
Car: 98 Z28
It is being a pain because we can't get the passenger side motor mount lined up. We took off the exhaust manifolds and the distributor cap for clearance but the motor still isn't going far enough back to clear the motor mounts. Any comments on my situation. Would it be easier to pull the tranny (700r4) and bolt it up to the motor and then stab the whole thing in or what?
Old Jan 27, 2001 | 05:01 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
As long as the tranny is in the proper position you should be alright. Make sure the tranny is angled up slightly, so when you slide the engine in, the back of the engine is lower than the front. I did my ZZ4 with the tranny supported by some stands and the motor fell into place. I know you are fighting this but the motor should fall into place. Keep at it.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
[This message has been edited by Rob P (edited January 27, 2001).]
Guest
Guest
Posts: n/a
I just did this a few months ago... well sorta it was a 305 but anyways...
You have to have the trans up high enough to get the engine lined up and hooked up to it, then you sorta have to force it back as you let it down, and I had to wrestle around with it a bit before it dropped in all the way. Prying is a good idea too.
Old Jan 27, 2001 | 05:36 PM
ede's Avatar
ede
can you say long a$$ pry bar and a BFH? it isn't easy, you just have to pry and force it then all of a sudden it'll fall right in.
ICON Motorsports
1st & 3rd
Old Jan 27, 2001 | 05:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
loosen the trans mount and pull the trans as far forward as it will go, and angle it up... its job is to be a PITA. But it will eventutally go together.
ICON Motorsports
Old Jan 27, 2001 | 06:56 PM
Mike86Z28's Avatar
Car: 98 Z28
Where is the safest place to jack the tranny up? Should I even think about using the torque converter?
Old Jan 27, 2001 | 07:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Large block of wood, like 18" of 2x12, under the pan.
ICON Motorsports
Old Jan 27, 2001 | 09:27 PM
CamaroMike's Avatar
Rob how the hell did you get TPI on a ZZ4 crate engine? The intake bolts will not line up!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 27, 2001 | 10:24 PM
Dan91Z's Avatar
i've seen alot of tpi zz4's at car shows recently..
you can do it with the high flow intake from edelbrock..
PN #3861 to work with after-market and early model heads,
PN #3860 if you have a factory tpi motor
My `91 Z28 Convertible
Old Jan 28, 2001 | 07:33 AM
Rob P's Avatar
Engine: ZZ4TPI
Bingo! I first had my 92 stock intake machined for the different bolt angle. I then bought an Edelbrock which is machined for both angles.
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
junior419
Apr 7, 2025 11:35 AM
69GTOby
Apr 18, 2016 02:34 PM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
