Weird oil pressure...
Old Feb 2, 2004 | 08:01 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
Transmission: 700 R4
I usually have been running 5w 30 weight oil in my car. Well the last time I got my oil changed I had them switch to 5w 40 weight oil because I had a small gasket leak. My oil has maintained the same pressure state for a while. Well I put oil in it the other day, I think I put 10 w 40 in it though. Just a quart . Well anyway the pressure is a lot lower than it usaully is lately. I idle at the halfway mark between the 0 and the 30, and when I go, have my foot on the gas it's around the 30 sometimes a hair over sometimes a hair under. Is this anything to panic about? Because well I'm panicking.
Old Feb 2, 2004 | 08:27 AM
ede's Avatar
ede
10 psi per 1000 rpm is good. might want to check it with a mechanical gauge
Old Feb 2, 2004 | 08:30 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
How much do those gages usually run?
Old Feb 2, 2004 | 09:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Just change the sending unit. The mech gauge is a great idea if you already have one, but it's a real PITA and extra $$$$ to go buy one and deal with the hassle of hooking it up, just to discover that your sending unit is bad like they always are.
The stock pump and oiling system in these cars usually does about 45-50 psi hot cruising, 20-25 hot idling.
Run 10W-30 instead of 5W-40; the "W" number is the base stock viscosity, and the other number is what it acts like with all of the stabilizers. Needless to say, it takes ALOT of stabilizers to provide a 25-number spread; and having your crankcase full of stabilizers instead of oil is probably not really a good thing.
Old Feb 2, 2004 | 03:13 PM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
Thanks much appreciated... I was reading in the other articles that a lot of the guys like the Mobil 1 synthetis 10 w 30 would you agree?
Old Feb 2, 2004 | 03:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
yes
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
