Realy need help
Car: 1984 Mint Z28 H.O.
Engine: 305 H.O
Transmission: 4 Speed Auto =| gettin megashifter
Realy need help
i was racing this civic today and my tranny was low on fluid, so it didnt shift right and i think i overrevved it, nows its hard to start, overheats in like seconds just idleing and makes a wierd noise from below the alternator, what chuold have gone wronge?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It could be a million things. How hgih did it rev? You could have broke something in your valvetrain would be my geuss. Pull a vale cover and check. You will also want to pull your pushrods because overreving usually ends up with a few bent ones.
Car: 1985 Iroc-z
Engine: 355 sbc
sounds like a valve took a dump on ya cause it coudlnt handle the fast pace of the high rev would explain your sound problem.
i would fear for your timing chain/gear as well.. that would explain both the sound and the hard starting issue
the heating issue points me to a thermostat not opening/have you even check your fluid? if it got hot it could have exploded the radiatror cap or leaked out the overflow...
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
i'd say ya over revv'd it and jumped time a little. probly sheared a few teeth off the timing set, 280,000 miles... i would not trust that ****.
i'm pretty sure 305s are free wheeling engines so you might have gotten lucky and not messed it up to bad.
what were you racing a Civic for anyway. not even worth the gas.
Engine: 305 H.O
not this one
this was supposidly the fastest civic around here, i jumped 1 car lenght at the start and it stayed like that till i let off the gas so i didnt blow up, i guess my addrenaline was going and i forgot she has 280k
Crash
Oct 31, 2000 07:22 PM
