valve cover removal
Old Feb 3, 2004 | 01:21 PM
insayne's Avatar
Car: 1984 Mint Z28 H.O.
Engine: 305 H.O
Transmission: 4 Speed Auto =| gettin megashifter
valve cover removal
i unbolted the valve cover and the top slides off the bolts but the bottom of the cover is like stuck, also, theres a metal tube coming out the back of the carb over to what i think is my brake thing, its in the top drivers side corner of the bay, and it goes through a little hole in the plate that holds the linkage for the carb, how do i move this outs the way?
Old Feb 3, 2004 | 01:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The metal tube screws into the carb base. A 5/8" open-end wrench on its nut and a 3/4" open-end wrench on the piece it screws into (to hold it still) will pop it right out of there.
Old Feb 3, 2004 | 01:56 PM
insayne's Avatar
Engine: 305 H.O
also
also, when i was trying to rip it off, i knoticed pices of rust and stuff, will it destroy my engine if some got into the valves and such? can i get it out?
Old Feb 3, 2004 | 09:42 PM
my84firebird's Avatar
Car: 1984 Pontiac Firebird
Engine: modded 5.0
Transmission: modded 700r4
Did rust particles fall in?? if so how much? Probably wont ruin your engine but it's usually common practice to use a shop vac and clean everything up while you've got the valve cover off. If you don't have access to a shop vac just use a rag.
When you're done putting the cover back on, change the oil. That way any contaminants that fell in will be removed.
Old Feb 4, 2004 | 12:03 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
when i was undoing that line on my car i went at it with only one wrench.
BAD MISTAKE!
I kinked the line. luckily it didnt break and i was able to bend it back. but ya, always use two wrenches on those. Thats one mistake that i'll never make again. heheh
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
