need info on a possible engine
Old Feb 5, 2004 | 09:20 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i found an ad in the newspaper for a 91 350 TBI without wiring harness for 800.
it came from a chevy pickup
anyone know the specs on it and how it would perform as a bolt on in my camaro? what if i upgraded the heads, cam and bored it to 383?
also can anyone know the stock hp and tq rating if i decided to just botl it in for now and upgrade later?
Old Feb 5, 2004 | 09:28 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: need info on a possible engine
800 is a bit high. You can get a used LT1 with accesories for around 700 - 1200. It doesn't have much more power than the 305. They share the same TBI unit and make only a little more power. Can't remeber off hand but i think it is 275 lb ft and 200hp. I may be off a bit but that is around what it is. You can always use it to start a furture engine build. I am not sure if the truck motors were all roller or not like your stock motor is so you will have to do a search on that.
Old Feb 5, 2004 | 09:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well if it isnt a roller, i can always make it a roller
Old Feb 5, 2004 | 09:48 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
True indeed.
Old Feb 6, 2004 | 07:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It isn't
It has the crappy swirl-port TBI heads. Garbage. Of course, you can always replace them....
More $$$$$$
If you have to spend all that money on some kind of crap to make it into something good, why buy the crap in the first place?
That's not a good deal at all. Keep looking.
junkcltr
Aug 2, 2019 11:12 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
MJS422
Oct 13, 2015 03:53 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
