Removing Harmonic Balancer
Old Feb 7, 2004 | 01:18 AM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
So my question is simple- how do i get the engine to not turn while i am using the puller to get this bitch off?!? The engine is on a stand with no heads by the way. thanks for any help!!!
Old Feb 7, 2004 | 01:28 AM
radiateu2's Avatar
pUT A LONG BOLT IN THE FLYWHEEL END OF THE CRANK SO IT MAKES CONTACT WITH THE STAND SO IT STOPS THE CRANK FROM TURNING
Old Feb 7, 2004 | 01:30 AM
ronterry's Avatar
Car: '94 Corvette
If I remember I was able to hold the balancer while using the puller.
Try covering the main bolt on the puller with anti-seize.
If nothing else works, you either have to put on a flex/flywheel and use a flex/flywheel turning tool, or some sort of belt grip deal on the balancer.
Ron
Old Feb 7, 2004 | 06:47 AM
ede's Avatar
ede
i usually use a screwdriver or pry bar to hold the puller, sort of slide it in above one bolt and below another.
Old Feb 7, 2004 | 10:53 AM
Beefy89's Avatar
Use an Impact Wrench.
Old Feb 7, 2004 | 11:47 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Is the starter still on the engine? Buddy of mine took vise grips and put them onto the flywheel. It then made contact with the starter and stopped the motor from turning.
Just an idea.
Old Feb 7, 2004 | 10:55 PM
Car: '86 IROC
Impact wrench= bad idea
I actually did finally get it off. what was happening was the removal tool was trying to thread itself into the crank threads, and ended up stripping the **** out of the end of the bolt. went to sears and got another one (good ole' craftsman) and it came with an attachment that mine didn't have that goes on the front of the puller bolt. came off real easy then. thanks for any suggestions
Old Feb 7, 2004 | 11:25 PM
Beefy89's Avatar
[QUOTE]Originally posted by Need4Speed1387
[B]Impact wrench= bad idea
I'm a diesel mechanic, works for me every time..
Old Feb 8, 2004 | 12:44 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Impact wremch
Old Feb 8, 2004 | 02:01 AM
ronterry's Avatar
Car: '94 Corvette
Hope you picked up an installer while at Sears. That tool is suppose to go into the crank thread
Ron
Old Feb 8, 2004 | 07:18 AM
ede's Avatar
ede
might want to find a tap to repair the threads you messed up with the first puller.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
roysatikas
Sep 7, 2015 08:08 PM
