More 416 flow numbers
Old Feb 7, 2004 | 02:36 AM
Kitch's Avatar
I've just finished reflowing my 416 heads with a 1.9" intake valve ( turned down manley 1.94" race flow valve).
Stock 1.84" valve in ported intake
Lift........CFM@ 28"
.05...........29.4
.10...........57.4
.15...........88.3
.20.........122.1
.25.........152.2
.30.........172.9
.35.........188.7
.40.........201.8
.45.........213.3
.50.........217.8
.55.........220.7
Modified 1.9" valve in ported intake
Lift.........CFM@ 28"
.05...........33.0.........+3.6
.10...........65.3.........+7.9
.15...........98.2.........+9.9
.20.........129.8.........+7.7
.25.........158.5.........+6.3
.30.........181.3.........+8.4
.35.........200.4.......+11.7
.40.........217.2.......+15.4
.45.........230.0.......+16.7
.50.........227.2.........+9.4
.55.........221.4.........+0.7
Not some of the best numbers for a 416 head but it's a start. A more scientific approach would have been to port a bit then flow test it rather than my port it until it looks pretty method.
I was surprised when I first flowed the head with the 1.84" valve how much the flow numbers between .45 to .55 kept increasing but now with the 1.9" valve they head the other way.
I also removed the intake valve from the head and reinstalled it back in the head up side down to block the valve guide hole. The runner then flowed 238 CFM .
At the end of the day I have a 305 head that pulls good flow numbers right in the range of most street sized cams.
Old Feb 7, 2004 | 08:55 AM
Vader's Avatar
Kitch,
Thanks for the update. Keep them coming. You've already proven the value of our efforts, and that a well-prepped SBC stock casting can outflow Vortec heads, as well as some of the other aftermarkets, and significantly outflow the World S/R Torquer 305s:
.05..........30.6
.10..........65.8
.15..........76.7
.20.........123.1
.30.........170.2
.40.........195.4
.50.........199.8
.55.........198.3
Old Feb 7, 2004 | 01:59 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Verifies my results.....
When ya get them bolted on you'll have to tell us how they work for ya.
Old Feb 7, 2004 | 04:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Just curious: Where did you get the #'s for the S/R 305's? Is that out-of-the box, or ported? They're not even close to what World claims.
Even so, every write-up I've seen on those heads had at least pocket port work done.
PurelyPMD
May 5, 2016 04:57 PM
69GTOby
Apr 18, 2016 02:34 PM
84redta
Sep 19, 2015 09:58 AM
Springster
Sep 13, 2015 01:38 PM
blackandblue02
Sep 10, 2015 08:19 PM
