oil buring and engine
Old Jan 29, 2001 | 11:03 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
does it possibly mean that ur engine can blow if u burn oil
350 vette engine
aluminum heads
235/60R15 BFgoodriches
3"flowmaster exaust
20% tint
Old Jan 30, 2001 | 09:46 AM
Desert86Roc's Avatar
You could be using oil because:
a) your rings are worn (high mileage engine)
b) valve stem seals are leaking (can happen to a low mileage motor)
c) obvious leaks on the ground (oil filter not sealed correctly, front or rear mains leaking excessively, etc.)
Which one seems to be more likely for your situation?
Mike Metzler (Desert86Roc)
Mike@SpeedworldMotorplex.com
[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For My Racing Page[*]86 IROC 305 TPI (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, Headers, no NOS)
Old Jan 30, 2001 | 06:10 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
it a from high miles. i just want to know who bad it is for the engine does it mean it is at the end of its life. it has about 100k on it. and it still has power it whips ur head back when you get on it. so I'm just curious? and how many miles can you get out of an engine. my has been raced a lot. Also it regulary came out of an late 80s corvette.
any ideas would be helpful.
thanx
350 vette engine
aluminum heads
3"flowmaster exaust
20% tint
Old Jan 30, 2001 | 08:55 PM
Russ-So Cal's Avatar
Run a compression test. Do it with the engine at normal operating temp. After checking compression dry, give the cylinders a shot of oil down the spark plug hole, and check them again. If pressure comes up, your rings are worn. If the pressure doesn't change, your rings are ok. If your pressure is ok, and you have no sign of worn rings, make sure your pcv valve works. If it is the valve guide seals leaking, you can replace them without removing the heads, if you have an air compressor.
Old Jan 31, 2001 | 03:53 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
thanx a lot
350 vette engine
aluminum heads
3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
