torque arm question
torque arm question
can somebody tell me what the torque arm is for or what it actually does and if i really need it. why do only some cars have it ? i switched my tranny from the 700r4 to a turbo 350 and i was wondering if there was a way to hook the torque arm back up without buying that kit from b & m. can it be welded ?
thanx
thanx
Car: yep
Engine: uhuh
Transmission: sure does
The torque arm keeps the pinion angle correct. Without it the rear end would spin straight up into the floor board.
If the pinion angle isn't right it could cause other problems. (u-joint failure, pinion bearing load, etc.)
I would definatly do it the right way, you should buy the kit.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
JH,
The torque arm limits the twisting forces of the rear axle when you accelerate and brake. Without it, the rear LCAs, shocks, and springs will take all the stress. First, you can expect the panhard rod to twist, then the springs to fall out of their perches, then teh car will settle on the shocks and put a couple of nice dimples in the rear cargo compartment floor. Finally, the LCAs will fail, tearing loose from the floor pan mounts.
Enough to make you want to get it hooked up yet?
Later,
Vader
"Make Me Bad..."
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad..."
ambainb
Apr 25, 2016 09:21 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
