Making a '93 block into roller cam block?
Old Feb 9, 2004 | 07:35 PM
Snake Oiler's Avatar
Car: 84 Z/97 Tacoma 4X4
Engine: 350 H.O Crate,slp 1 3/4,3"catback,Edelelbrock 1406,Edelbrock perfrormer Endurashine
The block has the raised bosses for the spider but is not drilled and tapped,same for the retainer on the front.
Can I just drill and tap them and install a factory roller setup?
Is this something I could/should do myself?
Thanks,Don
Old Feb 9, 2004 | 09:49 PM
Vader's Avatar
Yes, you can. You also need to be sure the tops of the lifter bosses are machined flat to accept the "dog bones" that retain the lifters.
Your other option is to use aftermarket roller lifters with retainer links.
Old Feb 9, 2004 | 10:04 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Make sure the two holes in front of the cam are there for the cam thrust retainer also. If you plan on using a factory style roller cam it has to be there.
Old Feb 10, 2004 | 01:27 AM
Just what I needed to know,THANKS!
Old Feb 10, 2004 | 09:02 AM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
Aren't all 87 an older GM blocks roller?????????????
Old Feb 10, 2004 | 09:15 AM
AJ_92RS's Avatar
No. www.Mortec.com/castnum.htm
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
