engine problems
Old Feb 10, 2004 | 07:17 PM
89Form-350's Avatar
Car: 1989 Firebird formula
Engine: 5.7L
engine problems
well here is my problem, one day my 1989 firebird formula 350 TPI started to bogg out and it died out. ever since than it runs very bad, but smell likes its running rich. black smoke come out of the exhaust. I have changed the o2 censor, fuel filter, and the Idle Control Motor, I had the mass air flow censor changed about 2months ago too. What could be causing it to bogg out? fuel injectors be clogged? or is it time for a rebuilt? i have 109,000 miles on it but i had the heads and everything rebuilt at about 90,000 miles. I just cant figure out whats wrong.
Old Feb 10, 2004 | 07:21 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
replace every sensor you can think of that wears out. You're on the right track with the O2 change. If it only smokes with a black color, then its not anything mechanically wrong. You may need a tuneup on that car, but for the most part it seems light and cheap to fix.
try starting with the ignition system... spark plugs, wires, cap/rotor, even a coil for some extra juice. looking at $100 in OEM parts or $150 in upscale performance (MSD blaster coil, MSD wires, etc)
Old Feb 10, 2004 | 09:17 PM
89Form-350's Avatar
Engine: 5.7L
should i change the distribuator and rotor and plugs and wires? the wires and plugs were changed before winter. what i dont understand is sometimes it runs fine then sometimes it runs like ****
Old Feb 11, 2004 | 12:13 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
well if it runs fine then turns to crap, it's a sensor.
Old Feb 11, 2004 | 10:43 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Might want to check the vacuum line going to the fuel pressure regulator. If you pours out you have a ruptered diaphram.
Old Feb 11, 2004 | 05:37 PM
89Form-350's Avatar
Engine: 5.7L
how about the distribuator and the rotor being bad? would that have the same effect by not firing all the cylinders?
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
