Help, My Car is Dead!
Old Feb 2, 2001 | 10:11 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I started up my car this morning fine and went back inside to let it warm up, when i came out it was dead. I started it back again and the idle kept going to 1500 and to about 200 and back to 1500 and so forth. Giving it gas wouldn't help much. Finally it died and now it wont start at all. I had my friend crank it while i checked the TBI and there was no fuel coming out of the injectors at all. I'm thinking its either the fuel pump, frozen fuel line, or clogged injectors?? I really don't know how to diagnose the problem and where to begin. Thanks for any help.
p.s. i changed the fuel filter a few months ago
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:120,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph before gears
Old Feb 2, 2001 | 10:53 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
At first blush I'd say pump or frozen lines. Even if you have some clogged injectors it's highly unlikely that they'd all clog up so badly in a day's time. How cold is it where you are? Do you have a way to check fuel pressure? Also, are you sure there's gas in the tank?
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: Accel 300+ wires, cap&rotor
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, Synthetic Oil, Flexlite Transmission cooler,
free mods, hopefully engine swap and 4th gen seats in the works...
Old Feb 2, 2001 | 11:00 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
I AGREE WITH I ROCK AND HOW COLD IS IT HTERE?
1983 CHEVROLET CAMARO
305 C.I.D.V8 BORED .30 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
MUSTANGS SUCK
Old Feb 2, 2001 | 11:39 AM
Car: 88 IROC
Transmission: auto
It was extremely cold this morning. Probably around 15 to 20 degrees. The gas tank is almost full. I'll just wait till 12 when the sun comes out, maybe it will unfreeze. Would putting dry gas in the tank help?
Old Feb 2, 2001 | 05:28 PM
Car: 88 IROC
Transmission: auto
After waiting a few hours, i cranked the car again and it started right up, but it only ran for 2 mins again and now its dead again. I told this to a mechanic and he says it doesn't sound like a fuel pump. But if it is, hes gonna charge me 50 for towing, 50 for diagnosing, 100 for fuel pump, and 300 for installation.
Can i disconnect the fuel line that goes into the tbi and crank the car and see if there is fuel coming out of the hose, or does this only work for carburated cars?
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
hokis
Aug 9, 2015 03:57 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
