uhoh.... Did i just mess up my timing when i swap the timing chain????
Old Feb 3, 2001 | 06:32 PM
z28cam100's Avatar
Car: 89 Trans Am GTA
I swapped out the crank in my 305 about 3 months back and when i reassembled i had the #1 piston at TDC. I lined the crank's timing gear up to the cam gear (with the dots which did not move)... Now my question is Does the cam turn twice for each turn of the crank?? If so could my timing be off by 180 degrees??? Any way to check easily? the engine is sitting back in my car with nothing hooked up to it yet.. Please tell me i didn't do somethin stupid...lol
86 Camaro
305, T-tops, flowmaster exhaust, B&M shift kit
"Real cars are built, not bought"-some smart guy
http://hometown.aol.com/z28cam100/index.html
Old Feb 3, 2001 | 06:39 PM
MrF-body's Avatar
no, i believe the crank turns twice for every single turn of the cam, but yeah the cam could still be off. with the #1 piston at TDC and the timing gear marks lined up both the valves for that cylinder should be shut, and as the crank is turned and the piston reaches BDC the exhaust valve should open.
have a beat to hell 87 GTA 305ci 700r4
t-tops,recaro,honeycomb wheels,digital dash
Old Feb 3, 2001 | 06:50 PM
ede's Avatar
ede
the way i do timing chains is to install the gears dot to dot, or crank gear at 12:00 and cam gear at 6:00 with the #1 piston at TDC. then you want to spin it 1 time and have both dots on both gears at 12:00. then drop the distributor in with the rotor pointing to #1 post on the cap.
ICON Motorsports
1st & 3rd
Old Feb 3, 2001 | 06:59 PM
z28cam100's Avatar
I lined the crank dot at 12:00 and the cam gear at 6;00... so does that mean that they are right??
86 Camaro
Old Feb 3, 2001 | 07:15 PM
snow427's Avatar
They're right. But the piston is at TDC on the exhaust stroke so you need to turn the motor over 1 full turn to get the piston to TDC on the intake so you can drop the distributor in.
Old Feb 3, 2001 | 08:24 PM
ede's Avatar
ede
i like the dot to dot because it's easier to see that the dots are lined up ,then i spin the engine to install the distributor. to me it would be too easy to have something out of line if the dots were both straight up.
ICON Motorsports
1st & 3rd
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
