replacing water pump
Old Feb 3, 2001 | 08:54 PM
sonnyb's Avatar
where can i find the right water pump for my 1991 csmro z28 with the serpentine belt system. i bought at least 3 water pump in the last 2 years. i have read post on this site saying get a reverse flow pump. where can i get this pump beside the chevy dealer.
Old Feb 3, 2001 | 09:12 PM
ede's Avatar
ede
any parts store or the dealer, just tell them what you have and they'll do the rest.
ICON Motorsports
1st & 3rd
Old Feb 4, 2001 | 01:21 AM
87RS402's Avatar
You might look into getting a high flow pump from summit or jegs. Higher flow will get you better cooling, we need all the help we can get.
Old Feb 4, 2001 | 01:41 AM
burnoutrpm's Avatar
are you running a reverse flow pump with your serpentine system? if not thats the whole problem and you can get a correct one at the local parts store just be sure it has no fitting holes on top of the pump if ti does it wont work!!(trust me i know, been throgh this before on my car loads of fun!!!) just make sure there is no fitting spot on the top of the pump and its reverse flow and you'll be fine they go for about 20$ from the parts store! forget gm wayyyyy to expensive!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) Edlebrock torker2 and a 600 edlebrock manual choke (1405)
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
