Weird smell
Old Feb 3, 2001 | 10:15 PM
89IROCZ
Guest
Posts: n/a
Weird smell
Today, I drove from my home town to my college. It is a 45 minute drive, all highway. When I parked, I smelled something funny. It seemed to be coming from the back of the car.... from either wheel well. It was a strong smell, similar to the smell of burning rubber, but not quite. Anyone have any ideas of what this is coming from???
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old Feb 3, 2001 | 10:24 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Kinda, maybe,sounds like the rear end fluid. That stuff stinks. But something would have to have gone wrong for that to be the case.
86 Z28
LG4 rebuilt tired again
Worn out 700R4
Have 400 short block waiting for a rebuild still planning it out
Old Feb 3, 2001 | 10:39 PM
89IROCZ
Guest
Posts: n/a
I was really afraid that it was possibly the rear end fluid, becuase I would imagine that if the rear end fluid is burning, then something is definetly wrong with it. I hope that is not the case. Guess I should change it and see what's inside...??
Old Feb 3, 2001 | 10:49 PM
Josh 91RS's Avatar
I sure hope it wasnt your e brake on I did that once when i was 16..."hmm...whats that funny smell....OH F * * *!!!!
(Really, you can't say that here...)
[This message has been edited by Vader (edited February 04, 2001).]
Old Feb 4, 2001 | 01:26 AM
87RS402's Avatar
Brakes smell like hot clutch ( same matieral ), Gear oil smells like sulpher. If your losing a wheel seal and it's getting on your brakes it will smell after use. I'd pull the wheels and look at the shoes. You'll be able to tell if thats it.
[This message has been edited by 87RS402 (edited February 04, 2001).]
Old Feb 4, 2001 | 02:20 AM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
Just throwing in another option... if your tires aren't balanced well or alignment is off enough, it'll wear your tires badly, which will smell like the tires burning... if you were driving on the highway though (assuming you were doing 70mph or more) you'd definitely notice the car shaking if it was the tire balance.. if it was the alignment, more than likely the tires would be worn on one of the edges more than the rest, depending on how long it's been like that. if not, then I suppose you should go back to the previous replies.
F-body-fan
May 4, 2026 09:42 AM
db057
Jan 10, 2020 08:55 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Dwayne614
Sep 29, 2015 11:05 PM
Glowsock
Sep 11, 2015 11:09 PM
