305 engine parts in my 350
Old Feb 12, 2004 | 04:06 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
What engine parts from an 88 305 tpi can I use with my 88 tpi 350. I know basically the entire tpi setup, but whatelse? Specifically:
EGR stuff and waterpump. (and will the water pump work on an 89 tpi 350?)
I'm talking about stuff that can be swapped without changing the engine makeup. Like I assume the injectors are cross compatible, but swapping in 305 injectors would be dumb.
Old Feb 12, 2004 | 04:16 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Everything will swap over. The engines are almost identical.
Old Feb 13, 2004 | 09:25 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
Everything except pistons, pins, rings, and other piston bore related parts. Everything else should work fine on a 350.
Old Feb 15, 2004 | 01:31 AM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
The block, crank, pistons, rings, heads, valves, cam, injectors are different. Everything else is the same. Things like valve covers, water pump, rocker arms, fuel rails are all the same.
84z96L31vortec
Aug 20, 2017 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
1nastygta
Aug 8, 2015 07:38 PM
