Windshield washer system
Old Feb 13, 2004 | 04:30 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
This one might be to easy for you guys,you have solved some tough ones for me latley.
I need to know what tubing / connecters are needed to assemble my washer system. The car we bought has the pump moter on the bottle,which does work however there is no tubing running to the wiper blades. Since it came like that I don't know what I need. Does anyone have a good pic of what the system looks like? I am not even sure if the squirter attaches to the wiper arms or the leaf screen or what. I am sure I can buy a kit just not sure what to buy.
Please help if you can.
Thanks,
Old Feb 13, 2004 | 05:50 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
The tubes & squirters run to the wiper blades. If nobody else can post pics I'll try to post some up later on today. Hope this helps
Old Feb 13, 2004 | 07:28 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Thanks, acescarrsRS
You probably don't need the washer system in Hawaii !!!!! like we do here in Michigan. Salt and snow all winter!
Anything you can offer would be a great help,
Thanks again
Old Feb 13, 2004 | 07:53 AM
ede's Avatar
ede
WAG since my car doesn't have one, or a wiper motor. i think it's 1/8" tube plus a couple of tee connectors and you should be all set. all you really need to do is look at where you have to start at and where you want to go, find the size of each fitting and how many branches and run the lines.
Old Feb 13, 2004 | 09:29 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
ede,
Yes, but I don't know how the tubing connects to the wiper arms. I suppose there is a factory clip and plastic tubing connectors or something, thats what I would need to know.
P.S.
Why no wash set up in your car ?
Old Feb 13, 2004 | 09:38 AM
Vader's Avatar
Usually, wipers aren't necessary at the track. Running in rain isn't that common.
My T/A is just a driver, but I can't remember the last time I used the wipers, either. I use Rain-X and keep the wipers parked on the shipping blocks so the blades don't lose tension.
Old Feb 13, 2004 | 12:42 PM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
You must not live in the snow belt like I do. Michigan winters are brutal. Actually the car is my 16 year old sons, we bought it in October and unfortunatly he has to drive it around in the winter. We have been restoring it and it is really starting to look good.
Bottom line, he has to use the wipers around here.
Old Feb 13, 2004 | 06:04 PM
Car: 89 RS
Ok Tom here you go. First, you run the hose from the washer fluid pump along the driver side fender lip area. Second pic shows where the hose enters the firewall, it's right behind the brake booster, Then comes out of the top area by the screen. I circled those points
Old Feb 13, 2004 | 06:06 PM
Car: 89 RS
This pic shows where the squirters are on the wiper arm & which way they squirt. There are 2 of them & they clip onto the arm. I don't know the part #'s for them.
Old Feb 13, 2004 | 06:08 PM
Car: 89 RS
This pic shows how you feed both wipers with the hoses. You can see how it goes through the screen also.
Old Feb 13, 2004 | 06:12 PM
Car: 89 RS
Ok last pic. Sorry Moderators, I know I posted more than 3 pics, but last one I promise You can't really see it too good but the hose running on the wiper arm is smaller than the hosing before it gets there. Just use an inline tee to get to a smaller hose size. Also it snakes through the spring at the bottom of the arm. If you don't know what spring I'm talking about I circled it so just pull your arm up a little then you'll see what I'm talking about. PM me if you have any other questions. Hope this all helps & good luck on your little project
Old Feb 13, 2004 | 09:09 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
If you have trouble finding the connectors, just head down to Home Depot and go to the irrigation section. You can use the connectors and t-connectors for lawn and garden drip systems. They are small enough to fit.
Old Feb 20, 2004 | 07:01 PM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Been on vacation
Hey guys, especially aces, thanks alot for all the time you put into your response to my wiper question. I am continously reminded how great the folks on this board are. I hope I can help you guys some day !
Thanks again.
Old Mar 15, 2004 | 03:59 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Thanks again
Thanks acescarrsRS again for posting the pics. I installed the entire new wiper / washer set up this weekend and it works great! Having the pics sure made it easy.
Old Mar 15, 2004 | 04:29 AM
Car: 89 RS
Hey Tom, I forgot all about this thread Glad to of been some help to you. I know how hard it is to understand an explanation of things without pictures so that's why I posted all those. I was on vacation & had time to take those pics anyways Glad your project turned out good. Laterz
-Anthony
Old Mar 3, 2017 | 02:53 PM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
Re: Windshield washer system
Did you need to remove that black plastic assembly with the screen in it in order to run the hose through the firewall?
Old Mar 3, 2017 | 08:54 PM
Drew's Avatar
It's been 13 years, why wouldn't you just start a new thread?
The easy way to go would be to remove the wipers and the cowl screen. Or if you want to fiddle around longer than it'd take to remove the parts, you might be able to fish something semi-flexible (such as weed-eater line) through the holes, and use it to pull the hoses back through. But it'd be easier to just pull the screen.
Old Mar 3, 2017 | 09:01 PM
Axle/Gears: 3.08
Do you need to remove the wipers in order to remove the screen?
The easy way to go would be to remove the wipers and the cowl screen. Or if you want to fiddle around longer than it'd take to remove the parts, you might be able to fish something semi-flexible (such as weed-eater line) through the holes, and use it to pull the hoses back through. But it'd be easier to just pull the screen.[/QUOTE]
Old Mar 4, 2017 | 12:43 AM
Drew's Avatar
Yeah, but it's easy. Lift up on the arm, and slide the little tab at the bottom away from the arm, then they pull right off. Then there's one 7mm screw in the middle that has to come out, then the cowl screen just is snapped in. Carefully pry up at the clips and it should pop off easily.
Bohemian
Aug 15, 2017 05:11 PM
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
m00n420
Sep 11, 2015 02:39 PM
Saxondale
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
