Cherry Picker Screwed!!! Help!!!!
Old Feb 3, 2001 | 07:27 PM
Mike86Z28's Avatar
Car: 98 Z28
When jacking up the motor from the ground, after about a foot off of the ground the cherry picker won't go up anymore and there is no pressure at the pump (where I jack it up at). Ealier it was jacking fine and then we let the motor down and went to jack it up again and it woulden't!
Old Feb 3, 2001 | 08:20 PM
ede's Avatar
ede
is the bleeder screw tight? the oil lever correct? not over loaded? try to let it down and then jack it up again to let out any trapped air.
ICON Motorsports
1st & 3rd
Old Feb 4, 2001 | 02:12 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Sounds to me like you're low on oil in the hydraulic cylinder. No oil = no pressure to pump into the ram!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Block is STILL in shop! (Waiting for my to buy the rods!)
ASE Certified Master Tech
Starting to look like the Kicker poster child!
Old Feb 4, 2001 | 02:20 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Out of oil would be my first guess also.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bigold4x4
Sep 28, 2015 05:21 PM
