70's camaro 350 cam
Old Feb 14, 2004 | 12:36 PM
bigj85z-28's Avatar
Car: 79 z-28
Engine: Built 406 w/ Nitrous Works 250 shot
Transmission: TCI Th-350
Axle/Gears: 8.5" 10bolt 3.73 and Auburn Pro
70's camaro 350 cam
does anyone know where i can find info on the cams used in the 350s of the early 70s that were rated at 375 horsepower. I need to know the lift and duration specs to determine what heads to go with. Thanks.
Justin
Old Feb 14, 2004 | 02:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.compcams.com/Technical/Ca...ML/128-169.asp go down to page 148, it's the "346" grind.
You don't really want that cam. I've had it, I can tell you first hand, there's lots better cams out there nowadays than that one. Nothing wrong with a solid cam though.
That won't tell you what heads to get.
It originally came in motors with regular, plain vanilla, stock, 186 "double-hump" castings (among a few similar others).
Old Feb 14, 2004 | 02:12 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You can try www.NastyZ28.com for the factory specs, but I don't recall them having the cams listed.
Old Feb 15, 2004 | 01:19 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Thats the old LT-1 cam, but the LT-1 only had 370hp in the Corvette... it was rated 360 in the Z28.
.458"/.484" lift and 317*/346* duration
(Intake/Exhaust)
Probably not a terrible cam, but wouldn't be my first choice for the street. I've heard 350s and 327s with that cam though... sounds pretty hairy.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
