won't start
Old Feb 14, 2004 | 06:12 PM
82Z28NAZ
Guest
Posts: n/a
won't start
1990 Formula
LO3
no pre-existing problems... got to work with no problems... went to leave work... won't even turn over... not even a click. battery has plenty of juice but still nothing
anyone have any idea what might be causing this?
Old Feb 14, 2004 | 07:44 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I had something similar happen a while back. In my situation, the Control Module in the distributor went bad. I would probably check that first. If I remember correctly, you can get a new one at Autozone for around $35.
Hope this helps.
Good Luck.
Old Feb 14, 2004 | 10:33 PM
82Z28NAZ
Guest
Posts: n/a
the dizzy's brand new.
not only will the car not turn but the starter's not even engaging
Old Feb 15, 2004 | 01:44 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
could have a broken starter id check your clutch saftey switch, check yoru starter connections and groundings. heres a good one....turn the head lights on and try to start the car if the lights dim than the starter is getting power. will make things easier go from there and let us know
Old Feb 15, 2004 | 09:35 AM
82Z28NAZ
Guest
Posts: n/a
the starter's brand new. so is the positive lead going to it
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
