fast idle
Old Feb 4, 2001 | 04:43 PM
luke j's Avatar
Car: '87 GTA hardtop, '86 IROC hardtop
Engine: 385 DFI, 350 carb
Transmission: T-56, T-5
Axle/Gears: ls1 torsen 10-bolt, 9-bolt disc
fast idle
i have a 87 gta with a 350 tpi, may problem is sometimes when i drive my car the engine will idle way above where it should. at operating temperature in park it will idle at about 1400 rpm. i thought maybe it had a bad air bypass motor so i cleaned it out with a good air intake cleaner. that seemed to help for about two days. it idled at 600 rpm in park. but two days later it was back to 1400 rpm. this problem is killing me on gas mileage and it drives me nuts because i have to cram down on the brakes to stop at a light and hold the car still. please help.
Old Feb 4, 2001 | 04:48 PM
BTS88IROC's Avatar
I am assuming by what you said you mean you cleaned out the iac valve. Instead of just cleaning it did you set it though? And why don't you try taking it apart and cleaning it. There should be an article in the tech section about it i believe.
Old Feb 4, 2001 | 07:22 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
very interesting. My car has been doing the exact same thing. I have adjusted it correctly so I would assume the computer is getting bad information from somewhere. My idle in drive will be like 900 when it should be 700.
'89 Formula 383 TPI
Old Feb 4, 2001 | 07:46 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
Is your timing too advanced?...do you have a vacuum leak at the TB maybe?
Old Feb 5, 2001 | 03:48 PM
89PFB's Avatar
did you check the TPS(throttle postion Sensor) cuz that same thign was happening to me...but mine was worse whent he engine was cold it would idle at 3 grand...triyng to stop the car like that jsut burned up brakes....
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
