L98 vette heads
Old Feb 15, 2004 | 03:03 PM
fastredtruck's Avatar
Car: 88 gmc 1500
Engine: 496
L98 vette heads
I just bought a pair of aluminum heads casting #128 for $100.
They are the non D port ones with 58cc chambers. What can I do to make these a decent set of heads? I plan on polishing the chambers and the exhaust ports and just smoothing out the intake ports with some 80 grit rolls. Since I bought them bare ill need valves. I want Manley Race Flo's. Can I go with 2.00 and 1.55 valves without shrouding or putting in bigger seat inserts?
Deos this sound good?
Old Feb 15, 2004 | 04:40 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Yes.... The valves from a LT-4 or Fastburn head are the way to go. (bigger, lighter) You can go a little further on the intake porting. lots of potential there.
Old Feb 17, 2004 | 02:38 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
summit sells the manley raceflo valves you are looking for. they are 2.00/1.56" part #man11500-8 and #man11501-8. not in catalog though, gotta ask for em. definately the way to go i'd say. does not require new valve seats. also those heads can be ported for some good gains. stock they dont flow all that great though.
Old Feb 29, 2004 | 10:34 AM
Car: 88 gmc 1500
Engine: 496
I was looking at the specs on the 2.00 and 1.55 manley valves and thery are a bit shorter about .010" then normal valve. This shouldnt cause any problems since the valve train is adjustable, right?
Old Mar 2, 2004 | 11:11 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
The exhaust ports are kind of poor on those. Some porting there will help quite a bit.
lt500r55
Sep 1, 2021 01:30 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
86White_T/A305
Aug 17, 2015 12:16 AM
