new alternator, new battery, no charge
Old Feb 15, 2004 | 06:08 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
i have a new alt. and battery and new belt, but i cant get my car to keep a charge. ive got volts to the alt, and the wire to the starter, but still no charge! after the car runs for a little bit, it will not crank back. i have to jump it off. any suggestions?
Old Feb 15, 2004 | 06:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked the condition of the three wire harness that plugs into the back or bottom of the alternator?
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
with key on, you need power at all the wires at the alt, one will be lower than batt, the others will be batt
Old Feb 18, 2004 | 06:22 AM
Engine: 355
ill check the plug. i know i got power to the rear wire. ill also check the three wires. thanks.
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
drumstixer
Sep 29, 2015 03:02 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
