anything good about 14101081 heads?
Old Feb 15, 2004 | 08:40 PM
Z-Monkey's Avatar
Car: 83 Brlntta in Z28 clothing
Engine: 305 LB9 POS until 350....
Transmission: hurting 5 spd- Crunchy...
I just bought a donor car with what the seller said was a '89 305HO, but when I checked the heads they are 14101081's. They've got the funky center mounting valve cover bolts, and my casting guide said that they are camaro heads from 87-88, so I'm guessing the seller was wrong. Are these better heads than the regular 305 heads I've got? are these HO heads? is this going to make enough of a difference that I should swap engines while I wait to build my 383? or should I just stick with my puny 305?
Old Feb 15, 2004 | 09:12 PM
smithtc's Avatar
www.mortec.com shows:
14101081...87-95...305
They are (center bolt) HO heads..or mainly the heads that came on TPI 305s.
Don't know what 305 heads you already have...to say if this engine is an improvement or not.
Why spend time and money on any 305 while your building a 383?
Old Feb 15, 2004 | 09:27 PM
Z-Monkey's Avatar
I'm not going to be spending any money on this engine, I bought a parts car for the tranny and posi and this engine happened to come with it and runs great. Knowing me, it'll be NEXT summer byt the time I get around to building the 383, so I'm either looking for a really cheap 350 to swap, (and then maybe build up) or maybe fate just happened to place this 305 HO here for a reason. either way, I'm not going to pour any money into it, just the weekend to swap it.
Old Feb 15, 2004 | 09:47 PM
smithtc's Avatar
The 89 305 may or may not have come with the L98 cam (207/213 @ 0.050 and .415/.430 lifts w/ 1.5 rr).
The heads will be 1.84" intake and 1.50" exhaust valve sizes if stock. Plenty of posts for these types of heads and porting (flow results, pictures, etc.) Same basically as the 416 heads (pre-86). I would at least do a mild bowl blend on them, and use headers, and it will have good power. Or sale the nice running engine and get better parts for the 383
HTH
Old Feb 16, 2004 | 07:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
THere were no "HO" motors that came with centerbolt heads. Therefore they are not "HO" heads.
If the car doesn't say "HO" on the side of it, and if it doesn't have a carb and 3.73 gears and all that HO stuff, then it's not a "HO" motor. People have reduced that title to a mere buzzword.
They are non-swirl-port 305 heads from 87 LG4, TPI 305 from 87 to 82, and the L69 and LG4 that was used in the Monte Carlos in 87 and 88.
So they're about the best 305 heads you can get with center-bolt valve covers. But since the "HO" designation was dropped after 1986, they are not "HO" heads.
Old Feb 16, 2004 | 07:12 PM
Z-Monkey's Avatar
do you mean TPI 305 from 87 to 92? I'm guessing that is what this engine is. He said that it was injected, but he swapped in an Edelbrock intake and an older non-CC q-jet and then sold the injection stuff, so I can't check that. but is does seem to have more power than my other 305. maybe it's just in better shape. the heads are much cleaner, for one thing. What sort of horse did the TPI 305's put out in 89?
Old Feb 17, 2004 | 11:56 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
As RB was saying, the REAL 5.0L HO motor ran from '83-86, with a 4bbl carb, special air cleaner and some other stuff.
The heads on those HO motors were either #416 or 601 (rarely). They had perimiter bolt valve covers as well. The heads you have are just as good as those, maybe a little better. I wouldn't stress over it though if you are just replacing the engine anyway.
Old Aug 2, 2020 | 07:59 AM
Jeremy Brown's Avatar
Re: anything good about 14101081 heads?
These guys don’t know what they’re talking about those heads are high performance heads. Why spend any money on a 305, well because they are better than the 350 in my book. I did a stress test on a 350 and a 305 and the one that lasted longer was the 305.
Old Aug 2, 2020 | 08:00 AM
Chevy has people fooled that the 350 is better so that they sell more of them but those junk 350s are just junk. They can’t hold up to heat as good as the 305s because of the thin cylinder walls. The real junk engine was the 307 but never the 305
Old Aug 2, 2020 | 08:24 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That or thermodynamics.........
Seriously, are you an editor at the Onion?
Old Aug 2, 2020 | 08:42 AM
pg29's Avatar
Car: 88 GTA
Old Aug 2, 2020 | 09:29 AM
PaulyC's Avatar
Holy crap, create an account just to reply to a 16 year old thread with some BS about a 305? Bang up job bro!
Old Aug 3, 2020 | 11:07 AM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
Old Aug 3, 2020 | 11:09 AM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
hey,you are right(sarcasm).can you leave now and check on the other ridiculous conspiracy theories you were chasing when you got sidetracked(lol)
Stevobass
May 9, 2012 09:23 AM
IROCtheThird
Jan 20, 2009 11:33 PM
blackdemon89ta
Jul 7, 2005 10:55 PM
Opha
May 6, 2003 10:24 PM
RSCamaroGuy92
Jul 17, 2002 03:46 PM
