400 sbc pulley setups
Old Feb 15, 2004 | 09:06 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
OK,
I have a 406cid motor. All the pulleys from the 305 I had in the car were transffered to it. I since removed the smog and a/c pumps and am now left with pulleys that have extra grooves not being used etc etc. I only need a pulley for the Alt, long water pump and PS. What setup are you guys using? I have a serpentive belt and a regular PS belt. I need to clean up the ebay. Any advice would sure help. If I forgot to mention something please tell me. Thanks.
Old Feb 16, 2004 | 04:59 AM
ede's Avatar
ede
just look for a donor SBC or 90*v6 and take everything off it. it'll save you a lot of time and agrivation if you get everything from one engine.
Old Feb 16, 2004 | 01:50 PM
ttt
Old Feb 16, 2004 | 05:52 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Ede already answered the question...go to a donor serp car and do the complete swap...
Is there another question in here somewhere that I missed?
Old Feb 16, 2004 | 10:42 PM
HatchetJack's Avatar
Be sure which water pump you have. I believe all serpentine pumps turn reverse of a V-belt pump. If it is a smooth pulley on the pump it is ment to drive on the back side of the belt or reverse of the V-belt pump. Not sure of the setups which used both belts---anyone know for sure???
Jack
Old Feb 17, 2004 | 12:26 AM
Jack
I will check on the pump issue. I was hoping to upgrade my pulleys as well, not just swap them out from another SBC. I dont really need more hp as my motor has enough already, but I would like a better pulley system. I understood what ede was saying. When I dont fully understand how something works I like to get more than one opinion.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
