New to 3rd gen need help
Old Feb 15, 2004 | 10:21 PM
NatesL98's Avatar
Car: 1990 Iroc-Z
I have a 90 iroc 5.7 with the speed density system. My problem comes when I take off from an idle there is a hesitation. Sometimes it is worse that other times, but it does not happen all of the time. As a matter of fact if I drive my car all day it might happen twice. Also don't know if this has anything to do with it but it has a miss as well. But with the miss it does not miss all of the time. I can't even tell going down the road but at an idle I can feel it. Now I have changed all the common tune-up commponents but other than that don't know where to start. I have done searches and have read other post but nothing like this has come up. Could it be TPS, EGR, injectors??????
COULD SOMEONE PLEASE HELP!!!!!!!!
Old Feb 15, 2004 | 10:57 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Try check the EGR valve. If its still the orignal then its definitely time to replace it. Maybe a tune as well would do wonders for your engine.
Old Feb 15, 2004 | 11:02 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Could be fuel related to. Either pluged injectors or a failing fuel pump.
Old Feb 15, 2004 | 11:34 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Try replacing your fuel filter, also do you have the correct gap on your spark plugs? Theirs really a ton of things it could be. What all have you replaced?
Old Feb 16, 2004 | 12:08 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
You did the simple tune up, plugs, wires, dist compon., fuel filter, pvc, air, oil. Did you then set the TPS and IAC? You did read through the FAQ right? Checked out all our cool stuff (shameless plug, yes I know). I would start there in order to have the basics covered and out of the way.
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
